Installation & Licensing
3ds max 2014 crashes on startup on Windows 8
4 REPLIES 4
2154 Views, 4 Replies
My 3ds max crashes on startup. I have tried installing the 2012,2013 and 2014 versions and they all crash on startup. Except for the 2012 one which runs for a minute then crashes. It works on all my other computers (which run windows7). Is the problem windows 8?
My specs are as follows
i7 3770k
gtx 650 ti
windows 8 pro
Need help asap
4 REPLIES 4
TravisNave
The problem is likely video card driver.  Make sure you are running a WHQL certified driver.
Autodesk Forums:
in reply to: TravisNave
I have updated my driver to the latest WHQL certified driver and it still
does not work
pmaloney5
I am experiencing this exact same issue with Win8 Pro trying to get 3ds max 2014 to install. It installed fine on win7.
in reply to: pmaloney5
I am also having the exact same problem on my ASUS laptop running W7.
Max runs fine on my desktop PC with W7.
Ive tried all the possible fixes I could find. Max used to work on the exact same laptop.
Administrator Productivity
