Installation & Licensing
3DSMax Objects not Visible in Viewport
2 REPLIES 2
6316 Views, 2 Replies
I am currently using 3DSMax Design 2012 (Windows 7) (64 Bit).
After importing an AutoCAD model it seems fine at first, but once i start to scroll in and pan/3d navigate...different aspects of the model starts to get blurred and more often than not they disappear completely!
Has anyone experienced these problems before? Any sudgestions on how to fix?
There might be something wrong in the setup. I am quite confident that my graphics card is up to spec.
Cheers.
2 REPLIES 2
TravisNave
Welcome to the community.
It very well could be the video driver you are using.  What is your card / driver?
Autodesk Forums:
Florian.Coenen
1.: select all objects into the scene and group them (Main menu --> group --> group)
2.: go to the move tool click on it with the RMB. possibly the values for x,y and z are really large
3.: type in 0, 0, 0 in order to bring the object to the worlds origin.
4a.: assign a standard shader to the objects and enable the 2-sided option.
4b.: or you can assign a "Normal" modifier to the objects and enable "flip Normals"
Best Regards,
Florian
Florian Coenen
Administrator Productivity
