I obtained the whole folder of 3ds studio max from my school
I went to install and it said
" Istallation complete. Some products failed to install"
Failed = Autodesk 3ds Max 2012
3dsMax Composite 2012
Log
2012/2/20:20:27:48 rebekah REBEKAH-PC === Setup started on REBEKAH-PC by rebekah ===
2012/2/20:20:27:48 rebekah REBEKAH-PC Launch
2012/2/20:20:27:48 rebekah REBEKAH-PC An instance of setup is already running. Only one instance of setup can run at a time.2012/2/20:20:27:59 rebekah REBEKAH-PC === Setup ended ===
2012/2/20:20:34:23 rebekah REBEKAH-PC === Setup started on REBEKAH-PC by rebekah ===
2012/2/20:20:34:23 rebekah REBEKAH-PC Launch
2012/2/20:20:34:23 rebekah REBEKAH-PC An instance of setup is already running. Only one instance of setup can run at a time.2012/2/20:20:34:25 rebekah REBEKAH-PC === Setup ended ===
2012/2/20:20:34:41 rebekah REBEKAH-PC === Setup ended ===
2012/2/20:20:27:50 rebekah REBEKAH-PC === Setup started on REBEKAH-PC by rebekah ===
2012/2/20:20:27:50 rebekah REBEKAH-PC Launch
2012/2/20:20:34:43 rebekah REBEKAH-PC PageOpen LaunchDialog
2012/2/20:20:35:21 rebekah REBEKAH-PC PageOpen LicenseDialog
2012/2/20:20:35:48 rebekah REBEKAH-PC PageOpen ProductInfoDialog
2012/2/20:20:46:18 rebekah REBEKAH-PC PageOpen ProductSelectionDialog2
2012/2/20:20:46:22 rebekah REBEKAH-PC PageOpen FullProgressDialog
2012/2/20:20:46:22 rebekah REBEKAH-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): G:\!!Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\rebekah\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/20:20:46:22 rebekah REBEKAH-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=3
2012/2/20:20:46:25 rebekah REBEKAH-PC PageOpen InstallCompleteDialog
2012/2/20:20:46:37 rebekah REBEKAH-PC === Setup ended ===
2012/2/20:20:49:43 rebekah REBEKAH-PC === Setup started on REBEKAH-PC by rebekah ===
2012/2/20:20:49:43 rebekah REBEKAH-PC Launch
2012/2/20:20:55:52 rebekah REBEKAH-PC === Setup ended ===
2012/2/20:20:49:48 rebekah REBEKAH-PC === Setup started on REBEKAH-PC by rebekah ===
2012/2/20:20:49:48 rebekah REBEKAH-PC Launch
2012/2/20:20:55:53 rebekah REBEKAH-PC PageOpen LaunchDialog
2012/2/20:20:56:32 rebekah REBEKAH-PC PageOpen LicenseDialog
2012/2/20:20:56:39 rebekah REBEKAH-PC PageOpen ProductInfoDialog
2012/2/20:20:57:00 rebekah REBEKAH-PC PageOpen ProductSelectionDialog2
2012/2/20:20:58:19 rebekah REBEKAH-PC PageOpen FullProgressDialog
2012/2/20:20:58:20 rebekah REBEKAH-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): G:\!!Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\rebekah\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/20:20:58:20 rebekah REBEKAH-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=3
Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted.
Uninstall this product from your Control Panel > Programs
