Installation & Licensing
2014 Online Download Issue
7 REPLIES 7
Message 1 of 8
Cadmanto
532 Views, 7 Replies
I am currently running 2012 at work.  In talking to our IT department, they have given me a serial number and a product key to use on a home license.  What I am looking to do is download 2014 using these codes.  Maybe I am looking in the wrong location on the Autodesk website, but in my first attempt, I found the product download section and when I tried inputting the info into the fields it wouldn't take them.  Then I tried downloading the 30 day trial of the Inventor Suite for 2014.  That downloaded and I saved the setup file, but when I went to run it, it gave me an error message that said the file was not a compatible 32bit system.  I selected the 64 bit version.  While I am not at home to give the exact message, I am going on memory to some degree.  Can anyone instruct me as to how to get this downloaded or upgraded on my home PC?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: Cadmanto
Are you sure your home computer is a 64-bit OS?  Odd that you would get that error otherwise.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 8
Cadmanto
in reply to: TravisNave
Travis,
Yes, I am sure it is 64 bit.
I am going to start from square one.  Here is the opening page from Autodesk.  If I have the serial number and the key code from work, where do I go to down load 2014 under my companies license?
I have never downloaded from this site before and considering I have struck out twice I need advice with this.
Thanks.
Best Regards,
Scott McFadden
Message 4 of 8
TravisNave
Technically, the trial should work. But whoever has the Subscription
account should be able to login and get the software as well.
Autodesk Forums:
Message 5 of 8
DarrenP
go this way: http://usa.autodesk.com/adsk/servlet/pc/index?id=19759203&siteID=123112
click on ask at the bottom>downloading & installation>software download links>i need to redownload my product>autodesk suites
DarrenP
Message 6 of 8
emily.xu
I think you can download a 32 bit version to see if work.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Message 7 of 8
emily.xu
in reply to: emily.xu
Can you install the product now? If still need any help from us, please update the post.
Emily Xu
Product Support
Message 8 of 8
Cadmanto
Emily,
Sorry I have not gotten back to you on this thread.
My IT department ended up getting me the 2013 discs for install.  I ended up doing that version.  I will try and make it a point to try what has been suggested.
Thanks for your input.
Inventor Suite 2012
Windows 7 Professional
Intel (R) Xeon (R) CPU 3.47 GHz
12.0 GB Memory, 64 bit OS
Best Regards,
Scott McFadden
Administrator Productivity
