Installation & Licensing
2010 Installation Problem
5 REPLIES 5
BoydChristensen8747
519 Views, 5 Replies
When we do an initial install of AutoCad 2010 and try to run the program we get a "Runtime Error R6034". We have had AutoCad send us a 2 duplicate disks and still get the error. Please advise.
5 REPLIES 5
This is not an Autodesk problem. It's actually a problem with your computer. You have mismatched C++ Runtime dlls on your OS that is causing this issue. You may need to reinstall your .NET Framework 3.5 SP1. What is your operating system?
Autodesk Forums:
We are running Vista.
You may need to do a .NET Framework cleanup and reinstall .NET Framework 3.5 SP1. I would start there.
Autodesk Forums:
Can you please say me where is the  .NET Framework Cleanup Tool ?
TravisNave
in reply to: arquitt1995
Administrator Productivity
