Ask a simple question for AIMS2013: Since we cannot use viewer API for Fusion Viewer. Is there any API that I can enumerate all layer groups, layers by their names, then I want set them to visible or invisible?
Right now I using server side code to turn them on/off, I found it's a little bit slow for vector data. When I try to turn on/off raster data from WMS Server, I found it's very very slow, I cannot see any change in the screen, only I can find the raster layer is on or off by create a pdf file of map image, then I found the visibility of my raster layer is on or off. Please help me this small technique but can help me resolve big issue. Thank you.
