Infrastructure Map Server General
Message 1 of 3 (720 Views)
Exercises in Autodesk MapGuide Enterprise 2011 Getting Started Guide
720 Views, 2 Replies
11-19-2012 03:24 AM
I'm using Autodesk Infrastructure Studio 2013 (v2.4.0.5208) and I;m working through the exercises in the Autodesk MapGuide Enterprise 2011 Getting Started Guide using the Sheboygan sample data.  When I attempt the exercise to connect to an Access database everyhting appears to go fine until I click on 'Test Conncetion'.  I then get an error message :
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
What am I doing wrong?
Valued Mentor
Message 2 of 3 (702 Views)
Re: Exercises in Autodesk MapGuide Enterprise 2011 Getting Started Guide
11-20-2012 05:34 PM in reply to: tony.witham
If this is 64-bit MapGuide/AIMS, then the ODBC driver name may be different
- Jackie
Product Support
Message 3 of 3 (683 Views)
11-22-2012 07:36 AM in reply to: tony.witham
If you are on a server, or system without Office, you might not have any drivers at all.  http://www.microsoft.com/en-us/download/details.aspx?id=13255 will set you up with what you need.  Be sure to match the bit-ness of Map Server.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
