Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Exercises in Autodesk MapGuide Enterprise 2011 Getting Started Guide
2 REPLIES 2
tony.witham
995 Views, 2 Replies
I'm using Autodesk Infrastructure Studio 2013 (v2.4.0.5208) and I;m working through the exercises in the Autodesk MapGuide Enterprise 2011 Getting Started Guide using the Sheboygan sample data.  When I attempt the exercise to connect to an Access database everyhting appears to go fine until I click on 'Test Conncetion'.  I then get an error message :
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
What am I doing wrong?
2 REPLIES 2
jackie.ng
in reply to: tony.witham
If this is 64-bit MapGuide/AIMS, then the ODBC driver name may be different
- Jackie
NateMoore
If you are on a server, or system without Office, you might not have any drivers at all.  http://www.microsoft.com/en-us/download/details.aspx?id=13255 will set you up with what you need.  Be sure to match the bit-ness of Map Server.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
