I'm using Autodesk Infrastructure Studio 2013 (v2.4.0.5208) and I;m working through the exercises in the Autodesk MapGuide Enterprise 2011 Getting Started Guide using the Sheboygan sample data. When I attempt the exercise to connect to an Access database everyhting appears to go fine until I click on 'Test Conncetion'. I then get an error message :
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
What am I doing wrong?
If you are on a server, or system without Office, you might not have any drivers at all. http://www.microsoft.com/en-us/download/details.aspx?id=13255 will set you up with what you need. Be sure to match the bit-ness of Map Server.
