I'm having issues with a model that I built. The model is a solar field aprox. 40 acres. Nothing to elaborate. My problem is that part of my model disappears when i pan around the solar field. One i zoom in closer the model reappears. Due to this problem I cant create a story board. Any ideas why this is happening?. I'm using R14. With a i7 Dell, 32 GB ram, 64 bit.
Mike
Go to Options and make sure that Show Backfaces is turned on.
Did the backfaces solve the problem?
I wonder if the solar field consists out of single solar panel models or if this is one huge model?
If the first one is the case you might turn on "max LOD" in the model explore for the city furniture assets or the fitting asset where the solar panel models belong to. Just cklick on the little white box (house) which will get some "windows".
if there is just one big giant model you may go back to the config dialog and switch to "Use LOD" and increase the LOD Distance (10000m or even more).
Tell me if that worked out.
Andreas
