Hello all,
I am trying to create a Road style to use with an airport. I can do almost all of it and get it to look pretty good except for the transition between two styles. Where I transition, I want one style to just stop and the other to pick up (see attached image). Does anyone know where I can edit the transition style between two styles on a design road? I have tried the intersection style and that doesn't seem to do it. In the attached image, I don't want my material to repeat when transitioning.
Hi Jay,
I am responding broadly because I cannot see much of the second roadstyle in the image you included.
Controlling the transition length distance between two roadstyles is not a supported feature in InfraWorks.
However, you modify the "Track Main Category" settings of each roadstyle, which will essentially guide which lane connects to which. There is some information about modifying the Track Main Category and other Road Style settings in the User Help topic "To Edit Road Styles": http://help.autodesk.com/view/ICD/2014/ENU/?guid=GUID-DCD9F1A3-1750-46F7-B062-0A7A11859BAE
Hope this helps!
