InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Flooplain Ploygon to Water Material in Infraworks
5 REPLIES 5
teesoy
685 Views, 5 Replies
Does anyone know if I can create a floodplain in Infraworks, and how to assign a water style to it?
5 REPLIES 5
ToddRogers-WPM
in reply to: teesoy
Is it a shapefile?  If so, when you configure it, then you can assign the water style to it.
Todd Rogers
teesoy
in reply to: teesoy
I can make a shape file, but will I loose the water surface elevations in the translation of it all?  I also have triangular faces with elevations. Ultimately I would like to use a surface as the Floodplain, and stylize it with water. Is that possible? Thanks!
bill.dhimitri
in reply to: teesoy
You might try the steps below.
Create a large transparent blue plane by copying an existing plane and scaling it:
Add the plane to your model, and set the Elevation value (this represents the level of the water):
The images below show the result:
Bill Dhimitri
InfraWorks Team
teesoy
in reply to: bill.dhimitri
Thank you for your solution, will this also work with the version of Infraworks that comes with the 2014 Premium IDS?  Our company has not yet upgraded our subscription, so I don't have R4 available yet.
andrewpuller3811
in reply to: teesoy
Yes, it does.
I just tried it in Infraworks 2014 R2 and it works fine.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
