How can I import a DXF file
hugopost01
Message 1 of 13
hugopost01
I cannot find the right procedure to engrave an DXF.
Pls analyze.
Hugo
Replies (12)
Message 2 of 13
jhackney1972
User the Insert DXF command to create a sketch.  Use the sketch to create the toolpath for the Engrave.
John Hackney, Retired
Message 3 of 13
hugopost01
OK, I dit all type of options but the dxf is placets at the bottem of the sketch.
Pls try it yourselve:
https://drive.google.com/file/d/1GkzvpbmMC0_k_OHmiQIwXtDccm-3tnJO/view?usp=sharing
Message 4 of 13
jhackney1972
A DXF is imported as a planar sketch, which yours did just fine.  The direction of Extrusion is up to you.  Please explain you problem completely as everything looks just fine to me.
Message 5 of 13
hugopost01
Ha, yes, you are right, it is working ok, also when I select a pocket with 2d pocket.
Tomorrow I make the finely attempt and hope the it is ok.
There are so many options in the traject from import to engrave.
Regards Hugo
Message 6 of 13
hugopost01
When I started, it was milling from the bottom.
After that I was lost.
Hugo
Message 7 of 13
hugopost01
No, it is not working, I need to mill the border and the figure.
Pls look at the attached picture
Message 8 of 13
hugopost01
Message 9 of 13
jhackney1972
You do not specify a lot of information to make a call on the milling tools you have access to so I just used some generic ones.  Model is attached.
 I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.  Doing this will tag the individual you are writing to.
Message 10 of 13
hugopost01
See next post
Message 11 of 13
hugopost01
See next post
Message 12 of 13
hugopost01
See next post
Message 13 of 13
hugopost01
I think I found the light.
First I make a block 20 mm and then I place the dxf on it, then I extrude the part I want in negative value.
After that,  there is a pocket who I can mill with 2d pocket.
Is this the correct way?
Regards Hugo
