It's great to see that Fusion has finally gotten a via stiching tool. It is however in my opinion somewhat unseless except for the most basic designs, unless I do not understand the tool and there's some hidden options I haven't tried/found.
Background: I have a 3 dm2 PCB with 6 layers containing USB (diff pairs), UART, GPIOs, GND planes, power plane etc. that will be EMC tested to CISPR 11 class B. I will definately want to stich it, either with the tool or manually, but since I have diff pairs, it puts restraints on the stiching. I have "large" silk screen text for part name, rev and PN for my PCB that I want to be able to route under. I have already in the design process worked through all silk screen component name placements. I do not want to redo this, but rather manually placing GND vias close to vital functions.
Issue: when performing stiching, the stiching feature does not adhere to (some?) design rules (custom keepout/signal-signal distance etc) as far as I can tell, but stiches whereever there's not a pad/via/trace conflict. I've had to amend my diff pairs to place them where they remove the vias, and polygon keep out zones where the diff pair layer change vias are. This works somewhat ok, but there seems to be no option to force the via stiching to not interfere with my component name placement since via stiching does not fully care about DR as far as I can tell. I would have wanted a specific rule section for stiching, where I can set specific distance rules for via stiching, tell it to not stich where there's text etc, alt be able to manually remove stiched vias that interfere with my design.
I do not mind manually placing GND vias close to my components since that gives me oversight and control, but as the stiching feature is working atm, it's close to useless for me. I do not undestand how it cannot respect the ruleset I have set up? Or am I missing features?
IMO, I should be able to delete individual vias in the stiching, convert stiched vias to normal vias, create via stiching keepout, or create a specific rule set for via stiching including do not sitch @ distance to specific signal & component names. Any two of those options would be acceptable.
Edit: adding a tented via option for stiched vias would also remove the entire issue since the text would then be on top of the solder mask with the via bellow. If this would be considered, I would definately need control of individually tenting top and/or bottom layer. TBH, this addition would actually be even better from a design perspective since it would save me space & work.
