I have the same issue installing ADR2010 and even ADR2011. I tried the link you posted but it is no more online.
Is it possible that that install option is online again?
Thank you for reporting this issue.
Please download and install the Visual Studio 2008 C++ Runtime manually from http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=2051a0c1-c9b5-4b0a-a8f5-770a...
Then try install ADR again.
Hope that this helps.
I continued to have difficulty downloading and installing individual components, but then I found this post regarding downloading and installing the full package which worked perfectly for me and others:
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10336080
This should link you to a 724MB download of the bundle. I also ran a .exe not a .msi. Good Luck! Let us know if it works for you as well.
