DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Cancel operation - software solution
0 REPLIES 0
Message 1 of 1
michael_mueller
396 Views, 0 Replies
Hi @all,
i want to use TrueView 2012 as ActiveX within C#/WPF. The Integration via a Forms formular hosted within a WPF WindowsFormsHost component ist working without any problem. The access to the API methods works as well.
What I'm looking for is the possibility to cancel an active operation so that another operation can be activated. For example, I am in Pan_Realtime mode and I want to change to View_3D_Orbit mode without pressing the hardware [Esc] key on my keyboard. The ActiveX component should only be operated by using the mouse and pressing e.g. a button to change the modes.
How can I cancel an active operation using a software solution?
Thank you very much for your answers.
0 REPLIES 0
