Hello all,
This will be my first time posting to this forum and with that being said, I am in need of some help creating a dynamic block.
I have tried everything to my knowledge and have also tried following "How-To" videos, but I am still having a hard time creating a block for a water valve.
The goal of this block is to have a valve symbol, as well as, text box with attribute definitions to display elevations and valve number.
The biggest issue I am having is when I "move" the block using the grip points I created, the grip does not follow with the block and is left in the same spot, as well as, when the visibility state is changed.
Another issue, is the attribute definition text does not display when the block is tested or inserted into a drawing, but it displays within the block editor.
I have attached a drawing of the block. Any help or advice is greatly appreciated and welcomed!
Thank you so much!
Dawn
