CAD Managers
*Rush, Randy
Message 1 of 11 (77 Views)
Sharing Files
77 Views, 10 Replies
05-16-2001 05:05 AM
I'm working in an enviornment where we have nine offices across the country,
all on a WAN. Our I.S. dept. says that opening the WAN up could be
problematic and that we can't do it at this time... we're NT based using a
frame relay. At present we're starting to use project teams across the
various offices but they can't share the files due to the restrictions on
the WAN. Now, I know it can be done, but being that I'm not a network
Admin. I'm not sure of the solution. Does anyone have an idea?
Randy
*Andrews, Tela
Message 2 of 11 (77 Views)
Re: Sharing Files
05-16-2001 05:27 AM in reply to: *Rush, Randy
The Person who setup our WAN between two offices did so simply by
programming our two Netopia routers (one at each location) to talk directly
to each other. I can print to a device at the other office, can login to
their domain or browse the computers through network neighborhood. We are
currently exploring Document Management software options that will make it
easier to keep track of documents for the same project between offices. I
believe the consultant did this by programming the ports on eaqch router to
talk to each other. They use NAT so they're somewhat secure and have been
totally reliable. Also, we we're originally on a Mac system when this was
setup, and have since migrated to NT so it is network independent.
I suspect there may be some limitation because you're using frame relay. I
would ask your tech what the specific limitation is. Also, I think our
setup takes some skill (another Tech I talked to tried it, and couldn't get
it to work), but I'd be happy to get you in touch with our ocnsultant.
Best Regards,
Tela Andrews
EPT Landscape Architecture
www.eptland.com
"Randy Rush" wrote in message
news:3E529923909A19B195280A68C8F3AC09@in.WebX.maYIadrTaRb...
country,
> Randy
*Rush, Randy
Message 3 of 11 (77 Views)
Re:
05-16-2001 06:19 AM in reply to: *Rush, Randy
Thanks Tela,
That would be great. I guess it's a problem most firms have. And our techs
think it would be an administrative nightmare to open up the WAN but there's
got to be a better way. Here's my info
Randy Rush
Corporate CAD Manager
MCG Architecture
O - 626-793-9119
F - 626-796-9295
E - rrush@mcgarchitecture.com
"Tela Andrews" wrote in message
news:7BC49ADE075499EC8A19C601F0ED8A13@in.WebX.maYIadrTaRb...
directly
to
I
get
> Best Regards,
> Tela Andrews
> www.eptland.com
> country,
a
on
> > Randy
*Diercks, Skip
Message 4 of 11 (77 Views)
Re: Sharing Files
05-16-2001 06:59 AM in reply to: *Rush, Randy
Randy,
We have 10 offices in Mi, Fl, and Oh with full T1 access from all
offices to our corporate office. Our network is wide open within itself and
fire walled from the internet. With the T1 we have pretty good bandwidth
and many users open files across the WAN. This works fine for relatively
small files.
Skip
Randy Rush wrote in message
country,
> Randy
*Parker, Bobby W
Message 5 of 11 (77 Views)
Re: Sharing Files
05-16-2001 07:11 AM in reply to: *Rush, Randy
http://www.Buzzsaw.com
*Rush, Randy
Message 6 of 11 (77 Views)
Re:
Only one problem with buzzssaw, it has a problem working behind a firewall.
I get transfer times in the "days" when uploading files and then it will cut
off unexpectedly at times.
"Bobby W Parker" wrote in message
news:f04e8b1.0@WebX.maYIadrTaRb...
*Parker, Bobby W
Message 7 of 11 (77 Views)
Re:
05-16-2001 08:02 AM in reply to: *Rush, Randy
We are having the same problem except we share a Cisco router with an office
in the same building. I thought we could open a port through the router to
enable both offices to share data on each others machine, but the people who
support our router suggested a fifteen thousand dollar server to share. I am
not sure how they want to share data this way, but it is probably through
the router. Does anybody have any experience sharing data across a router?
Other than the obvious security risks, it is doable?
*Rush, Randy
Message 8 of 11 (77 Views)
Re:
05-16-2001 09:54 AM in reply to: *Rush, Randy
Hey Skip,
do you have any problems with security? people messing around with files or
deleting files they should? Our I.S. is pretty adamant about not opening up
the WAN for fear of chaos. They also say they're no way to know who messed
up something. I want to put in place a system by where your title would
restrict you from certain permissions. lets say your a Jr. Draftsman, you
shouldn't be able to delete folders, only PA's PM's or JC's something along
that nature. Also I think that one person should be in charge of data
collecting and disbursement, and that person should be the JC or project
coordinator... but that's another issue, my main concern is getting our
network open, and we keep running into walls with these guys... any other
thoughts?
Randy
"Skip Diercks" wrote in message
news:E6C75EF670232B283C2B91221E0067D4@in.WebX.maYIadrTaRb...
> Randy,
and
> small files.
> Skip
> country,
a
on
> > Randy
*Elkins, Dan
Message 9 of 11 (77 Views)
Re:
05-16-2001 11:25 AM in reply to: *Rush, Randy
You should be able to do this easily with proper user/group management. You
can also turn on auditing and set it up to log pretty much anything.
Dan
*Marie-Noël
Message 10 of 11 (77 Views)
Re: Sharing Files
05-16-2001 11:38 PM in reply to: *Rush, Randy
To collaborate along with other project teams you can use the Electronic
Vault wich allow you to centralize Cad drawings either in the native
source format or Visualizable format.
According to your user's credential, people will be allowed to visualize
or fetch any CAD drawing through the Web Browser !
For project management purposes, the Program Office Tool lets you deploy
your processes and practices throughout the organization while providing
you key strategic information regarding any projects for executive
reporting and quick decision making.
To learn more about PMO software go to:
http://www.lanasys.net/english/pdf/pmo.pdf
country,
> Randy
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
