Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
pendean
2640 Views, 4 Replies
AutoCAD and Citrix FYI
List of Autodesk's "Citrix-Ready" XenApp certified products:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
4 REPLIES 4
TravisNave
in reply to: pendean
Dean, I appreciate the link.  Thanks!  I'll need to start testing this.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Here are some tips for keeping within the license agreement. There is a special purchase required to use AutoCAD and Revit with XenApp. Without it you are violating the end user licnese agreement (EULA). The specific verbiage for the EULA was posted in the forum here. Basically it says you can’t self-host an Autodesk application unless Autodesk designates it and you purchase a special license.
Some technical solutions that may be helpful for XenApp users are:
Map 3D requires post install scripts for all versions of XenApp it is supported on.
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Tags (1)
And…
System Requirements for Autodesk Citrix Ready products
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Thanks Doug, this is a great reference.
Autodesk Forums:
Administrator Productivity
