"darnold" <it
href="mailto:darnold@labellapc.com">darnold@labellapc.com> wrote in
message
href="news:f134a21.1@WebX.maYIadrTaRb">news:f134a21.1@WebX.maYIadrTaRb...
doesnt do anything... it changed my crosshairs but changed the angle of the
drawing with it... i want to be able to keep my drawing at a 35 degree look
but with 90 degree crosshairs...
"Dustin" <
href="mailto:dmorin@neumannmonson.com">dmorin@neumannmonson.com> wrote
in message
href="news:C77427C5D972ABFEBFA2B954865C8135@in.WebX.maYIadrTaRb">news:C77427C5D972ABFEBFA2B954865......
You can either do 2 things, go to tools>new
ucs>object and pick a line that you want the ucs to rotate to or type ucs
and change the x axis to the angle you want
"darnold" <it
message
"darnold" <it
message
"darnold" <would
message
href="news:f134a21.-1@WebX.maYIadrTaRb">news:f134a21.-1@WebX.maYIadrTaRb...
like to rotate my crosshairs to normal view but keeping my drawing at the
angle it is set as... How can you do it?
"Joe Melton" <
href="mailto:joemelton@pdceng.com">joemelton@pdceng.com> wrote in
message
href="news:AC0EDEC2B2EE35D530F09A5C6A9BF23A@in.WebX.maYIadrTaRb">news:AC0EDEC2B2EE35D530F09A5C6A9......
Here it is:
Type "SNAP" and hit enter
Type "Rotate" and hit enter
Type 0 and hit enter
Then hit F9 to turn snap off
You don't have to screw with all that UCS mess to
just rotate your crosshairs.
"darnold" <would
message
it?
"David_W._Koch" <If
href="mailto:dkoch@ewingcole.com">dkoch@ewingcole.com> wrote in message
href="news:f134a21.5@WebX.maYIadrTaRb">news:f134a21.5@WebX.maYIadrTaRb...
you can generate the image, you can post it to the Customer Files newsgroup,
with a note here stating you have done so.
The Customer Files newsgroup
can be accessed via the web-based interface at -->
href="http://discussion.autodesk.com/WebX?14@@.ee940b5">http://discussion.autodesk.com/WebX?14@@....
[watch for word wrap], or via a newsreader at
news://discussion.autodesk.com/autodesk.autocad.customer-files
[watch for word wrap].
ZIP all files prior to posting. If you use the
newsreader access, make the ZIP file an attachment to your post. If you use
the web-based interface, there is the usual place to type explanatory text for
your post, and an edit box at the bottom where you type in the path and name
of the ZIP file, or use the Browse button to navigate to it (usually
easier).
David Koch
Member of the Autodesk Discussion
Forum Moderator Program
