Mike,
As the "diligent moderator" who moved your post the other day, let me say
that you read far too much into that action than is there. As a "CAD Guy"
myself, I would think that other "CAD Guys" have at least a passing interest
in computer science. However this particular newsgroup is for technical
issues directly related to ADT, not general discussion of general computer
science topics. Therefore, your post was moved to Take5, which is where
general discussion topics should be placed, as opposed to simply being
deleted, which is what could have happened in OTHER moderated newsgroups.
And I see that it has gotten quite a response over there. Much more
discussion, I would wager, than it would have gotten here.
As for software stability, I agree that it would be nice to have software
that never crashes, but ADT is a pretty complex piece of software. In
addition to the thousands of lines of code that it contains, it also has to
mesh with AutoCAD2000, which has even more code. Each service pack of
AutoCAD has the potential to do something to ADT. And even the most
diligent QA process is most likely going to miss something. I can assure you
that the guys in Manchester would love to produce completely bug free
software and that they are striving toward that goal, but it will most
likely be a goal that won't be met any time soon, if at all. While I don't
doubt your claim to have written software that never crashes, I do doubt
that it was/is nearly as complex as ADT/AutoCAD, or nearly as CPU and
memory-intensive.
The reasons for your crashes, as someone else here has indicated, can be
many, and not all directly related to ADT.
Regardless, to answer your original question, Win2000 is far more stable
than any other Windows program I have ever run on, and yes, it is worth all
the "administrator hassles".
As for your issues with the viability of ADT for CD's, I agree also that
there is more improvement needed in the sections and elevations, and I
expect that these will be an evolving feature (and they have already come
quite a ways in 3 releases). In fact, they aren't inended, at this point, to
be CD-ready objects. But someday they will be. Be that as it may, they are
still a sight better than NOTHING to generate sections and elevations. At
the very least, you have a 2D object that you can use for a template for
your final section. And something that is usable as a design tool and
preliminary drawing object that is live-update-able (is that a word? )
from the model. That's a huge head start over doing it by hand. But without
the 3D model you'd have nothing at all.
Please do not email me privately with technical issues
Matt Dillon
Assistant Moderator - Autodesk Discussion Forums
The D.C. CADD Company, Inc.
http://www.dccadd.com
Mike Johnson wrote in message
<7E224F9C080AA947136204781EC7F0C4@in.WebX.maYIadrTaRb>...
