Sounds like you're doing the least amount of work needed, actually. You
If you make int. and ext. walls different cleanup groups, they won't
clean up at all. I don't think that's what you want, at least it's not
what most want. For the walls to clean up correctly, the components of
the wall just need the same priority(which you can find by editing the
wall style). You can make different styles for int. and ext. walls, but
you don't have to make them different cleanup groups...make sense?
Doug wrote:
> What is the best way of using these two? I am starting from scratch.
> Generally I use the "Solid Fill" wall style. Should I be setting up
> different styes for interior & exterior Walls? of just use the varible
> for thickness & heights? What are the advantages & disavantages?
> I have created:
> Interior Wall 8' with clean-up group IW8 (interior Wall 8')
> Interior Wall 8' with clean-up group IW9 (interior Wall 9')
> you get the idea... am I making too much work?
> Thanks
> Doug
Bob Kalinowski
Eberhard Systems, Inc.
