Thanks for the reply Joe, however I tried Method #1 and this did not work.
For the time being I uninstalled ADT2 and ADT3 erased the shared acad
directory and re-installed. Still no luck. I gave in and uninstalled ADT2
and re-installed ADT3 and all is fine now, except that I don't have ADT2
installed. I guess for now this is acceptable, I guess.
"Joe Eichenseer" wrote in message
news:F06DC85C1E9B568F53137088366B9ADD@in.WebX.maYIadrTaRb...
> From a search for "ac1st15.dll" in the Autodesk support knowledge base:
> (http://support.autodesk.com)
> Issue
> The following error occurs when you start AutoCAD or AutoCAD LT:
> A required .DLL File, AC1st15.dll, was not found
> Note: This problem does not occur on computers running Windows NT
4.0.
> This problem occurs when you start AutoCAD or AutoCAD LT on a
computer
> where both of the following conditions exist:
> a.. The path statement in the autoexec.bat file (added during the
> installation of the program) was later removed or modified.
> b.. The number of characters in the path statement exceeds the
limit
> allowed for characters in a path in the Windows 95 or Windows 98 registry.
> Solution
> Following are two methods you can use to correct the path
statements.
> Method #1
> Correct the path statement in the autoexec.bat file to point to
> C:\progra~1\common~1\autode~1, and then reboot the computer before
starting
> AutoCAD or AutoCAD LT.
> Method #2
> During installation, shorten the directory names for AutoCAD Release
> 14, AutoCAD 2000, AutoCAD 2000i, AutoCAD LT 2000i, or products based on
> these AutoCAD releases. For example, change the default directory,
> c:\program files\acad2000, to c:\acad2000.
> Additional Information
> Information about setting path statements is available from the
> following sources:
> Microsoft Windows 95 Resource Guide
> Copyright 1995 by Microsoft Corporation. All rights reserved.
> Microsoft Windows 98 Resource Guide
> Copyright 1998 by Microsoft Corporation. All rights reserved.
> The path information contained in the registry is not static. When
you
> start AutoCAD Release 14, AutoCAD 2000, AutoCAD 2000i, AutoCAD LT 2000i or
> products based on these AutoCAD releases, the path statement is rewritten,
> as follows:
> AutoCAD 2000- and AutoCAD 2000i-based products: The AutoCAD 2000 or
> AutoCAD 2000i path information is placed at the beginning of the statement
> in the APPATHS registry key.
> AutoCAD Release 14-based products: The AutoCAD Release 14 path
> information is placed at the beginning of the statement, and the AutoCAD
> 2000 path information is moved to the end of the path statement.
> If the combined paths then exceed the maximum number of characters
> allowed in a path statement in a registry key, the characters exceeding
the
> limit in the AutoCAD 2000 or AutoCAD 2000i path are ignored. AutoCAD 2000-
> and AuotCAD 2000i-based products then refer to their path statement in the
> autoexec.bat file. If the path statement in autoexec.bat was removed or
> modified, the error message occurs.
> Note: Network login scripts can overwrite path statements in the
> autoexec.bat file. Consult with your network administrator as to whether
> network login scripts should be modified to resolve this problem.
> Joe Eichenseer
> Senior Architectural Specialist
> Avatech Solutions
> Denver, CO
> "Darek Olson" wrote in message
> news:024D8735ED7B916DC9BC1A482F2136BB@in.WebX.maYIadrTaRb...
> > Does anyone have any thoughts other than that doesn't sound good?
> > news:D0A51C3FF3C3FD462A63EF69FF3F66EC@in.WebX.maYIadrTaRb...
> > > I have Adt2 SP1 installed and working properly. When I installed ADT3
> > > everything appears to load fine. Then when I restart the machine and
try
> > and
> > > run either ADT2 or ADT3 I get an error message stating that
AC1ST15.dll
> is
> > > missing or can not be found. I did a search for it a found it in the
> acad
> > > shared folder. If I uninstall ADT3 and fix ADT2, ADT2 will run again
> until
> > I
> > > re-install ADT3. What is going on here? I have installed these to
> programs
> > > together many times and have never had any problems until today.
