you can take a look at my website and read the readme file of my
software in the troubleshooting section and see if that solves your
problem
http://www.cadbazaar.com
Mike Rioux wrote:
> I am reposting this from about 30 minutes ago since I may have forgotten to
> include a subject line the first time:
> After selecting a pulldown menu that launches Design Center (ie.
> Documentation/Schedule Tags/Object Tags...), the Design Center window will
> not show Large Icons in the right-side window without first selecting
> another folder from the directory tree and then reseleting the "Object Tags"
> folder.
> Has anyone else encountered this? Know of a solution?
> Our system is set up to retrieve Design Center data from our network not the
> local HDD.
> Thank You,
> Mike
Nauman M
CAD Bazaar
*********NEW*********
Add AEC Objects to the Layers(lkey) you want, not the Layers ADT Wants!!
Add a Wall directly on the DEMO Layerkey, instead of switching it later.
Download the eval at http://www.cadbazaar.com
Need to easily Navigate to your Custom Content Folders?
Need Autolayering for Dimensions without going through Design Center?
Download the ADT Tools for ADT 2 & 3 at
