No, I don't think so.
"Mike Hutchinson" wrote in message
news:3EF1F88B.E045334B@bbsae.com...
> Did you happen to have Adt2i on the machine at one point?
> James Bednarz wrote:
> > Hi folks,
> > I've started recieving drawings from a consultant made using
> > Building Systems 3. We're trying to open them in ADT3.3 SP2 and it ain't
> > happening.
> > So, I attempted to install the OE for ABS3 and I get the following
error
> > message...
> > "Autodesk Building Systems 3 Object Enabler is not compatible with the
> > version of AEC ObjectDBX currently installed on this machine.
> > Please remove any older Object Enablers or update installed products."
> > The problem is that I did just that and removed an OE that was installed
and
> > also made sure sp2 was installed. AutoCAD 14 had also been installed on
that
> > computer so I removed that to be safe. Still no luck. It won't even
allow me
> > to re-install the OE that had been on there before.
> > Thanks for your input,
> > Jim Bednarz
> > IT Administrator/ CAD manager
