IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
eifion
283 Views, 4 Replies
AutoCAD
Hi
Is a vanilla copy of AutoCAD installed alongside Architectural Desktop and
can it be run on its own. This can be done with machanical.
Eifion Evans
4 REPLIES 4
in reply to: eifion
I'm running both at home. I do drawings for a
custom window manufacturer (sort of shop drawings) and I use plain vanilla
AutoCAD (well...I sooped it up just a bit 😉 ) for these drawings. An when I
want to play architect, I use ADT3.3. No problems. Even have VIZ3i running
fine.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
Eifion Evans
in reply to: eifion
Hi
Thanks for this, how do I start AUtoCAD on its own
it is not in the start programs menu.
Eifion
fine.
Hi
and
Eifion Evans
in reply to: eifion
Ahh.......now you want my dirty little secrets,
huh!
I'm part of the Autodesk Developer Network, so for
a small, phenomenal fee each year, I get ALL of Autodesk's software. I did a
totally separate install of both programs.
However, I think you could create a profile which
would disable loading of ADT software, pull out the AECARCHX menu, and create a
template file that uses no ADT objects or other "stuff". You could then use this
profile when launching Vanilla AutoCAD from the desktop (use the /p option; you
could call the profile Vanilla e.g.). You can probably even change the icon
appearance.
Hi
own it is not in the start programs menu.
Eifion
I want to play architect, I use ADT3.3. No problems. Even have VIZ3i running
fine.
Hi
and
Eifion Evans
in reply to: eifion
I'd set up a profile for vanilla AutoCAD as opposed
to loading another copy of the program
Hope that helps,
Dennis McNeal
Building Industry Division
Hi
Eifion Evans
