What's happened to copytolayer?
It is also missing from the "missing command list"
It is not an express tool as it was incorporated in AutoCAD a few years / releases back
Solved by maxim_k. Go to Solution.
Hi John,
Try my rough Lisp file (no error checking, don't change cmdecho, etc.) See attachment.
Load COPYTOLAYER.FAS (Tools -> Load Application)
Type COPYTOLAYER at command prompt.
Maxim
Does this work for Autocad for Mac 2016? I thought I loaded it yesterday, but when I tried using it today the command didn't exist. Would you mind walking me through the proper procedure for loading this file so that it stays without re-loading it each day?
Thank you for your help.
