AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
ORTHO while commands are running
7 REPLIES 7
Message 1 of 8
1115 Views, 7 Replies
In 2012, when using F8 as Ortho, it does not seem to work while there is a command running. Has anyone else experienced this, or is there a system variable I need to look for.
7 REPLIES 7
Message 2 of 8
Might be a keyboard issue. Did you try the toggle button at the bottom of the drawing window just to test? I know of no sysvar.
Message 3 of 8
got the same issue.. F8 works but not when you have a command active. then only CMD+L works
Message 4 of 8
Thanks, but it appears it is a little bug in 2012.
The workaround for now is to toggle the button on the statusbar.
Message 5 of 8
maxim_k
Yes, it is a bug.
BTW the same is true for F3 key - if you will try to toggle OSNAP on/off with F3 key when some command is active - nothing will happen.
When no command active - both keys F3 and F8 works for toggling OSNAP and ORTHO modes.
In fact I know tricky workaround, but this method is related with editing a file inside the AutoCAD application folder.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 8
same here. really annoying. unbelievable a bug like this one is still present in the final version (beta testers i'm looking at you)
Message 7 of 8
Wow, that is a really big oversight on Autodesk's part. Being able to toggle the osnap and ortho on and off in the midst of a proceedure is very important to the way I have learned to use the program. This really needs to be fixed!
I am playing with the trial version and for the most part am willing to overlook some of the inconveniences I have discovered but this might just be he deal breaker in the choice between Windows and Mac versions when we upgrade. Wow!
Smiley Mad
Message 8 of 8
HawkAIA
Thanks to assistance from Autodesk Tech Support on this it looks like they have a pretty good temporary fix. I have posted it at the message board below. It involves making a change to a cui file in the application package:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/osnap-toggle/td-p/2963240
Ignore the first few comments in the board related to version 2011 and scroll to my post at the end.
”Boost
