In AutoCAD 2013 when I try to change an objects plotsyle in the drop down menu of the properties inspector from "colour" back to "by layer" it automatically reverts back to "colour" when i click "by layer". There seems to be no way I can change an objects plotstyle back to "by layer". Does anyone know a work around?
Yes, this bug in AC 2013, when working in drawings with Named Plot Styles, still here (in SP1 too).
You can not change Plot Style of individual objects via Properties Inspector (and change Layer Plot Style in both Layers Palette and Properties Inspector)
The workaround is to use "old good" CHANGE command with "Properties" option.
Call CHANGE command, select objects you want to change Plot Style, hit Enter, then enter P for Properties, then enter PLotstyle option, then enter "By Layer", then hit Enter two times:
Command: CHANGE Select objects: 1 found Select objects: Specify change point or [Properties]: p Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/PLotstyle/Annotative]: PL Enter Plot Style or [?] <Normal>: Bylayer Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/PLotstyle/Annotative]: Command:
HTH
BTW: in AC 2012 with SP3 there is no such bug, i.e. you can use Prop Inspector to change Plot Style of objects in Named Plot Style drawings
Maxim
