In my student version of Autocad for Mac 2013, it can't seem to locate the plot style folder. When I click 'File - Plot Styles..', nothing happens. I do have the default folder of plot styles at /Library/Application Support/Autodesk/roaming/AutoCAD LT 2013/R19.0/enu/Plot Styles, full of great .ctb's I have used before in other versions of AutoCAD.
I made a screenshot of the PAGESETUP command, when I try to select a ctb file. When I select 'new' in this screen, I can make a new CTB and save it, but I can't find it in Autocad anymore. When I select 'Reveal in Finder', nothing happens...
How can I fix this?
Yes, it's working! The Plot Styles are working now, but still I can't export as PDF or 'Save as PDF' in the 'Plot' or 'Print' command. If I try 'Save as PDF' with other programs, it does work.. Only not with AutoCAD. Would that also be a preference I have to change?
If I try to make a PDF by exporting as PDF, I get an error: 'Continuous plot log could not be opened for write'..
Did you reset AutoCAD preferences? Or just you corrected path to plot styles?
If you did not reset - try this now.
If this will not help, maybe re-installation could help you.
Maxim
