Hi all
I trying to download Autodesk Advanced Steel 2015
But It's not download
Pl see picture for more detail
Thank all
use this link 😛
http://trial.autodesk.com/SWDLDNET4/2015/ADSTPR/DLM/ADSTPR_2015_WIN_64BIT_dlm.sfx.exe
Advance Concrete
http://trial2.autodesk.com/SWDLDNET4/2015/ADSTCP/DLM/ADSTCP_2015_WIN_64BIT_dlm.sfx.exe
Licence :
it may require autocad 2015 to run
DarrenP
Thx DarrenP for answer...
And duchoabn prevent further question here Robot 2015 link 😛
http://trial.autodesk.com/SWDLDNET4/2015/RSAPRO/DLM/RSAPRO_2015_Multilingual_Win_64bit_dlm.sfx.exe
1. There was indeed an issue with the Advance Steel download links a couple of days ago, but it was fixed and you can download or install the program from the website without any problems.
2. License message error : Advance Steel 2015 standalone licence (Trial lic. is considered standalone) doesn't work with an AutoCAD version that works with a network license. You need either a network license of Advance Steel 2015, or a trial / standalone version of AutoCAD to be able to start it.
3. Platform selection. By default Advance Steel 2015 sets itself during installation to start with AutoCAD platform (and if multiple AutoCAD installations are detected, it will always start with the last used AutoCAD). To control which AutoCAD is used for Advance Steel, you need to first start the respective AutoCAD version alone, close it, and then start Advance Steel. To choose a different platform for Advance Steel, you need to open "Management Tools 2015" (found in "All programs / Autodesk / Advance Steel 2015"), go to "Options" and change the settings under "Advance Steel Software behaviour" category.
and 150245 robot when advance steel and concete include building design suite ???
after pay xxx year subscription ???
i was wrong: http://knowledge.autodesk.com/support/advancesteel/downloads/caas/CloudHelp/cloudhelp/2015/ENU/AdvSt...
the license mismatch is probably whats causing the error
DarrenP
When is there going to be a Forum specifically for “Advance Steel 2015”
I want to learn how to use it. Does anyone know where to get tutorials?
hello everyone,
Will Autodesk Avanced Concrete 2015 run on AutoCAD 2014 ?
DarrenP
DarrenP
here we go:
http://forums.autodesk.com/t5/Advance-Steel/bd-p/2056
regards Udo
Can you please give us more information about when this error message appear ?
