AutoCAD P&ID General
Active Contributor
Jan-TSpD
Message 1 of 2 (897 Views)
Calculated properties manager Autocad PnID
897 Views, 1 Replies
01-20-2013 02:51 AM
Hello, i am having trouble with the Calculated Properties Manager in PnID. I want to create a new propertie combined from 3 other Project Properties and a General Property.
I have attached an image from the Calc Prop Manager. I can't get it done. Tried also the the following link to Autodesk;http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21024206&linkID=11705365
Is a more detailed Help available for this item. I have tried it on a project, since that time the project is corrupt and crashes each time i start the Project Setup Manager.
Regards, Jan
Distinguished Contributor
cadwomen
Message 2 of 2 (870 Views)
Betreff: Calculated properties manager Autocad PnID
01-21-2013 02:54 AM in reply to: Jan-TSpD
your link , are the only help, and the anserw is in there
Click the concatenating symbol (||).
kilck your first  part then put in || then the next part . BUT if one of them is not fillt you will see nothing
cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
