AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Expression Builder - Value Replace
3 REPLIES 3
red_dog113
426 Views, 3 Replies
I have a property of UNIT_WT with a Text value of 36,000.  I can not get a new property with the coma removed for the 36,000. How would you use the Expression Builder to replace or remove the , ? I tried everything I know!
3 REPLIES 3
To better understand the issue, can you please attach the sample drawing file?
Sridhar Subramani
Senior Product Owner
What I would like to do is remove the , in UNIT WEIGHT and Convert it to KG in the KG WEIGHT.
Hi, Brian
Find attached drawing.  UNIT WEIGHT property's "Data Type" in the BOM settings dialog was set to "Text" type.  So when you enter 56,000 ; it will accept the comma as well.
I have set Data Type to Numeric Type and the comma is removed which now shows the value as 56000.  KG WEIGHT is also converted into 56000.
Let me know if this is what expected?
Sridhar Subramani
”Boost
