AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Import .asc elevation model & contour lines
0 REPLIES 0
Message 1 of 1
HiAlHi
930 Views, 0 Replies
Hi everyone!
I use Autodesk Map 3D 2013 with Raster Image.
The task I would like to accomplish is to import an ESRI ASCII GRID elevation model and create contour lines.
What I did so far:
- created a drawing with the 3d template.
- assigned LL84 coordinate system
- created connection to my dhm.asc file (ESRI ASCII GRID) with coordinate system CH1903 / height in meters
- add this as layer to the map
- assign theme for nice colors
So far this works but the first strange thing here is that the imported layer it slightly rotated. (Might be due to projection)
Next step:
- create contour lines
A new layer is created with the contour lines and this layer is not rotated so it does not match exactly the surface layer.
My questions are:
Why is the surface layer slightly rotated after import?
Why does the contour line layer not match exactly the surface layer?
Anything I am missing/doing wrong during import?
Jochen
0 REPLIES 0
”Boost
