AutoCAD Map 3D General
Active Contributor
Message 1 of 4 (144 Views)
How do I break linked polygons created from New Feature from Geometry?
144 Views, 3 Replies
02-06-2013 11:53 AM
Hello, I'm using AutoCAD Map 3D. I had some geometry that I needed to convert into a shape file, so I selected on the shp layer "New Feature from Geometry".  Everything converted to join the shape layer, but now it is all connected.  I want to move/edit individual polygons but when I go to select one it selects all of them.
I've noticed I can "create new feature" one at a time, but I'd really like to find how to unlink them after I've converted them in bulk.
Murph
Message 2 of 4 (136 Views)
Re: How do I break linked polygons created from New Feature from Geometry?
02-06-2013 02:51 PM in reply to: Jfactory
New feature from geometery is designed to work one feature at a time. That allows you to add/edit the feature atrributes. To "bulk convert" you need to use the map export command.
Murph
Supportting the troops daily.
Active Contributor
Message 3 of 4 (120 Views)
02-07-2013 02:57 PM in reply to: Murph
Thank you, Murph!
Murph
Message 4 of 4 (116 Views)
02-07-2013 03:08 PM in reply to: Jfactory
Jfactory wrote:
Thank you, Murph!
You're welcomed.
Murph
You are not logged in.
Ask the Community
