AutoCAD Map 3D General
Member
Message 1 of 5 (103 Views)
Export to PowerPoint
103 Views, 4 Replies
03-13-2003 02:25 AM
What is the format or method to export a map project to Microsoft PowerPoint as a slide?
*David
Message 2 of 5 (103 Views)
Re: Export to PowerPoint
03-13-2003 12:13 PM in reply to: msprouffske
Screen capture to a BMP works although the file
size is large. Screen capture to GIF is good too.
David
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
What
slide?
*Rick
Message 3 of 5 (103 Views)
03-13-2003 08:52 PM in reply to: msprouffske
Rather than do a screen capture, use the PublishToWeb JPG or the
Independent JPEG Group JFIF (JPEG compression) plotter. If you don't
find these available, add them through the Autodesk plotter manager in
the control panel. If the map is going to take up most of the slide, I
use the Sun Hi-Res (1600 x 1280 pixels). This creates a jpg file that
is much smaller than a bmp.
Rick
*Anderson, Kenneth
Message 4 of 5 (103 Views)
03-14-2003 03:42 AM in reply to: msprouffske
There is a third party utility called BetterWMF that does a VERY nice
job on this. I use it on a daily basis. Best $100 that I ever spent
here on AutoCAD. (shameless plug!) They have a free working demo.
www.furix.com
You will have resolution independent vector based .wmf files to insert!
If you plan to do this on a regular basis you NEED this plugin.
*Hoen, Ken
Message 5 of 5 (103 Views)
03-19-2003 01:54 AM in reply to: msprouffske
Another good way to do this is to use the command
"saveimg".  The resulting dialog box lets you specify image resolution and
file type.
What
slide?
You are not logged in.
Ask the Community
