AutoCAD LT Forum
Welcome to Autodeskā€™s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
remove source address from printout
2 REPLIES 2
cvoonc
322 Views, 2 Replies
hi all,
I have a user  with autocad LT 2004, don't know why evertime she print out, there will be a line of text printed out together, how can I remove this text?
2 REPLIES 2
AcadAdamLT
in reply to: cvoonc
edit: I didn't read the Subject well enough! Made my earlier text seem very stupid, is it possible that you have a field of some sort there or a diesel expression?
Could it perhaps be a plotter setting?
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
cvoonc
in reply to: AcadAdamLT
I have found the solution, it's the plotter stamp, thank you for your reply.
ā€Boost
