I'd like to locate the PROPERTIES button in the Home Panel instead of, or in addition to, the View Panel. When I go into CUI, it won't let me move/copy it.
Solved by pendean. Go to Solution.
You want to copy just the button, or the whole panel that Properties resides on? CUI will let you do both, if you have read-write access to the CUIx file.
For the command only move, Grab it from the COMMAND LIST and drag it to the Home Panel you want to park it on.
