AutoCAD LT Forum
Fatal Error Autocad Lt 2014
9 REPLIES 9
Message 1 of 10
miguellage
939 Views, 9 Replies
We have been suffering Fatal error messages from the two computers in our network that have Autocad 2014 LT service pack 1 installed. We haven't experienced this problem in the computer with Autocad 2013 LT.
The message shown is as follows:
FATAL ERROR: Unhandled Access Violation Reading 0xa564555f Exception at fcfc58abh
Both computer are running Windows 7 Professional.
Graphic cards: Nvidia GeForce GTX 660 Ti
The problem seems to happen only when we access files located in our server's folders. If we copy the same file to the local hard drive, Autocad works fine and it doesn't crash.
We have tried adjusting graphic card settings: windows aero on & off, hardware acceleration on & off, but Fatal Error message continues showing.
Best regards and thank you in advance.
9 REPLIES 9
Message 2 of 10
braudpat
in reply to: miguellage
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
Please could you confirm that you have NO problem if the DWG is loaded from LOCAL hard drive !?
Please could you open your DWG with RECOVER mode to check if something is dammaged inside your DWG ?
The Health, Happy New Year, Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 10
miguellage
in reply to: braudpat
Hello from Puerto Rico.
Thank you for your response. Yes, files work fine from local drive but cause Autocad to crash when accessed from server. We have tried recover and audit but it didn't work either.
Best regards.
Message 4 of 10
pendean
What's the server OS? How are you conencted to it? speed of that connection?
What parts/elements/shared content/features of LT2014 are on the server? Are they the exact same ones as 2013's? Or are all three seats complete standalones (if you unplugged from the server no one's LT would suffer)?
There is nothing inside AutoCAD to manage the problem you describe.
Message 5 of 10
miguellage
in reply to: pendean
Hi, thank you for your response.
We started to experience this problem after we moved old files to a new server. Our former server ran Mac's OS X 10.6 and we didn't have any problem. The new one runs Mac's OS X Mavericks. We are connected trough a 1000mbps Ethernet connection. I'll ask our IT specialist about the details of the connection and I'll let you know.
All Autocad settings are stored locally. We use the server for accessing project's files only.
Our IT specialist suggested that the problem could be related with file's path exceeding Windows 256 characters limit. We use a lot of nested folders.
Thank you in advance. Best regards.
Message 6 of 10
pendean
>>>...file's path exceeding Windows 256 characters limit...<<<
Whatever your old server used to do/how it was setup needs to be replicated: you probably had the same nested pathing there too? Or did you all change all of that as well? Remember, your LT2013 PC remains unaffected and presumably none of your LT stations are MAC, correct?
Message 7 of 10
miguellage
Correct, none of our workstations are Mac, only server is. Our IT specialist just sent additional information:
I made a mistake, our former server ran OS X 10.5 Leopard, not 10.6
Our current connection is as follows:
The Ethernet connection is gigabit and the shares are served out using AFP and SMB protocols with an ACL list that has FULL CONTROL including delete.
Regards.
Message 8 of 10
akshara
I m suffering from fatal error on lt 2014. Why ?
Message 9 of 10
pendean
in reply to: akshara
You tell us: what triggered the fatal error?
What's new on your PC?
Message 10 of 10
Emmsleys
Hi @ akshara,
It'll help if you provide more information on how you got the fatal error issue. This will help when providing suggestions for you to try.
Some questions:
Is this happening with all of your drawings or only a specific few?
What OS are you running AutoCAD LT 2014?
Is this only happen for you? or multiple people?
Sarah Emmsley
Technical Support Specialist
”Boost
