Hello there everyone...
Hopefully someone will see this and know the answer.
I am working with Autocad 2014LT and am having some trouble with the "DVIEW" command...specifically, it doesn't seem to exist. When I type "DVIEW" it engages "DDVIEW" and I get the 3d viewport menu, but I see no way to create or modify a perspecive view...at least not in the way that I was used to in previous versions.
I opened a file that I created previously and it opened and I was able to use it as a base for this new file, but could not modufy the perspective in just about any way...
My first question...does "DVIEW" exist in LT?
Second, if SO, how does it work in the new interface?
(The old method, just for reference, would be type "DVIEW" then select the items you wanted in the view, generally "ALL", then the options came up, I often would use the "2 Camera" interface, and then set the cameras, and then play with the "Lens zoom" etc...Can I do any of that anymore?)
LT will allow you to view perspective if it was set in the full version of Autocad, but you cannot turn it on or alter it unfortunately. You can move around a 3D object using 'view point' but if you want perspective you will have to draw that yourself the old fashioned way (for each viewing angle).
