AutoCAD LT General
Member
Message 1 of 6 (385 Views)
Crash on AutoCad LT 2012 load.
385 Views, 5 Replies
03-01-2013 11:08 AM
Yesterday I went to open AutoCAD LT 2012 and after the splash screen froze, was greeted with the "AutoCAD LT Error Report" window.  With increasing thoroughness I first "repaired", then "reinstalled" then removed and reinstalled, then removed using the Autodesk instructions for removal and reinstalled, then reinstalled c++ 10 runtime, then reinstalled DirectX, then uninstalled with manual edits to references in the registry and reinstalled, then used the psebuninstalltool.exe utility to uninstall and reinstalled (from DVD).
Same result each time:  Splash screen, "First Run Initialization", then "AutoCAD LT Error Report" window.
I would like to access my drawings.
Please advise -
pendean
Message 2 of 6 (376 Views)
Re: Crash on AutoCad LT 2012 load.
03-01-2013 11:32 AM in reply to: BridgHunt
Windows System Restore should always be your first "fix" when software suddenly stops working: try it, it may still help.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
Message 3 of 6 (370 Views)
03-01-2013 12:02 PM in reply to: pendean
Used Windows Restore to point before last Critical Windows Update.  Problem Solved.  Wished I had tried that first!
-- Thanks!
Charles_Shade
Message 4 of 6 (361 Views)
03-01-2013 01:15 PM in reply to: BridgHunt
Do you allow Windows to update on its own?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
Message 5 of 6 (356 Views)
03-01-2013 02:05 PM in reply to: Charles_Shade
Yes.  Windows 7, 32 bit.  Would it be better to install the updates manually?
Charles_Shade
Message 6 of 6 (341 Views)
03-01-2013 06:28 PM in reply to: BridgHunt
Or mosttimes not at all.
.NET updates can be real buggers. I've not noticed C+ so much but if you do these manually you at least know which mucked with what when something happens.
I made the mistake of updating the Mouse and Keyboard the other day. Never again.
You are not logged in.
Ask the Community
