AutoCAD LT Forum
Crash on AutoCad LT 2012 load.
5 REPLIES 5
BridgHunt
610 Views, 5 Replies
Yesterday I went to open AutoCAD LT 2012 and after the splash screen froze, was greeted with the "AutoCAD LT Error Report" window.  With increasing thoroughness I first "repaired", then "reinstalled" then removed and reinstalled, then removed using the Autodesk instructions for removal and reinstalled, then reinstalled c++ 10 runtime, then reinstalled DirectX, then uninstalled with manual edits to references in the registry and reinstalled, then used the psebuninstalltool.exe utility to uninstall and reinstalled (from DVD).
Same result each time:  Splash screen, "First Run Initialization", then "AutoCAD LT Error Report" window.
I would like to access my drawings.
Please advise -
5 REPLIES 5
pendean
in reply to: BridgHunt
Windows System Restore should always be your first "fix" when software suddenly stops working: try it, it may still help.
BridgHunt
in reply to: pendean
Used Windows Restore to point before last Critical Windows Update.  Problem Solved.  Wished I had tried that first!
-- Thanks!
Charles_Shade
Do you allow Windows to update on its own?
BridgHunt
in reply to: Charles_Shade
Yes.  Windows 7, 32 bit.  Would it be better to install the updates manually?
Charles_Shade
Or mosttimes not at all.
.NET updates can be real buggers. I've not noticed C+ so much but if you do these manually you at least know which mucked with what when something happens.
I made the mistake of updating the Mouse and Keyboard the other day. Never again.
”Boost
