By default, the command window is docked. The docked command window is
the same width as the AutoCAD LT window. If text that is entered becomes
longer than the width of the command line, the window pops up in front
of the command line to show the full text of the line.
You can resize the window vertically by dragging the splitter bar, which
is located on the top edge of the window when it is docked on the bottom
and at the bottom edge of the window when it is docked at the top.
Undock the command window by dragging it away from the docking region.
When you undock the window, the floating window is the size it was
before you undocked it. You can move the floating command window
anywhere on the screen and resize its width and height with the pointing
device.
Dock the command window by dragging it until it is over the top or
bottom docking regions of the AutoCAD LT window.
Bill Gilk
PSG Product Support, Americas
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
kesa wrote:
> Can any of you guys out there help me. I have restored the command
> line and now it won't dock....so what do I do now????
> cheers
