AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Changing short commands
11 REPLIES 11
Message 1 of 12
jbeatty2222
3259 Views, 11 Replies
Can you change the commands in Lt 2014. I want to change the copy command (CO) to (C) and make cirlce (CC)?
11 REPLIES 11
Message 2 of 12
drjohn
in reply to: jbeatty2222
tool > customize > edit program parameters (acadlt.pgp)
Just follow the format..  Be cautions not to make another alias that uses the same "C" (or whatever).  The last one in the list will override the first one. (eg: C,  *CIRCLE  may be overwridden by C,   *FOO if FOO is in the alias list last)
DJ
Message 3 of 12
jbeatty2222
in reply to: drjohn
Thanks working so far.
Message 4 of 12
Bob_Zurunkle
I'd recommend leaving the stock ones alone and coming up with an unused one, simply because if you're in a drafting office environment, there might be reason to use someone else's PC and vice versa.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 5 of 12
As I tell my kids, you live in my house, you live by my rulesSmiley Wink
Message 6 of 12
dgorsman
in reply to: sthompson1021
Hah!
Or, provide a separate PGP file for each user.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 7 of 12
jvanabel
Can you run that by me please? I have AutoCAD LT 2014 and am trying to change the command for double line. It is currently dline. I want to change that and other commands... I don't know what it means to go to tool, customize, acadlt.pgp...
Message 8 of 12
sthompson1021
in reply to: jvanabel
Do you use the ribbon or classic workspace?
Message 9 of 12
jvanabel
I used the ribbon. Manage, Customization, CUI User Interface
Jon T. Van Abel
Message 10 of 12
sthompson1021
On the manage tab, select the edit aliases button. That will open the PGP file. From there change the keyboard shortcuts that you want at the bottom of the file in the user defined section.
Message 11 of 12
jvanabel
Thank you
 for your quick reply. It is just what I need to do but there seems to be a problem yet. My command for double line isn't on the list to start. I can type in the command 'dline' and do double lines all day, but I can't find the command for it in the aliases. Can I create my own?
jvanabel
Message 12 of 12
hwalker
Yes you can create your own,
Just make sure that you don't create one which replaces one that you use.
EG
I have
DL,      *DLINE
Which allows me to do a double line and this is in the USER DEFINED SECTION
However In the main section you will find
DL,         *DATALINK
Which my DL replaces.
Howard Walker
Left Handed and Proud
”Boost
