I am working on drawing supplied by someone else. In this drawing virtually all the lines are polylines whereas I just want to work with 'ordinary' lines. It causes problems with filleting lines as it automatically turns new lines into polylines. Is there a way to turn a polyline into an 'ordinary' line or do I just have to redraw each line or put up with the problems it causes?
Solved by Charles_Shade. Go to Solution.
Thanks for the response. I am doing that but sometimes after using explode the individual lines retain their polyline properties and so when I then fillet the line the combined lines become a polyline again.
May be that the first EXPLODE was a Block
EXPLODE again.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
