AutoCAD LT Forum
Autocad Lt 2014 Array
1 REPLY 1
Cronk1
577 Views, 1 Reply
Is there a way to use the array definition box like in acad lt 07?
Is there a way to explode the array?
How to edit the array?
(obiviously I am have trouble with the new array tools)
1 REPLY 1
edwin.prakoso
in reply to: Cronk1
You can use ARRAYCLASSIC (you have to type it). If you use it frequently, you may want to assign an alias or shortcut key for that.
If you want to learn more about new array command, you may want to read this: AutoCAD 2012 - new array command
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
”Boost
