Hello again.
Now trying Autocad LT 2014, now on the windows 7 PC, HP Z620, quaddro FX 2000.
Multiple problems/annoying things found (i think).
There are still no Certified Drivers for AutoCAD LT available, hardware accelleration?!
When i try to work with a drawing that has multiple viewports, it becomes "laggy", as did 2012 and 2013. Driver problem, hardware accelleration?
when opening a blanc template and copy/paste 1 block in this template, it is terrebly slow, not to work with. in the right bottom corner there is a message "unrecognized" when panning or zooming. after panning or zooming it's gone. (see printscreen)
can anyone help me?
attached:
drawing with 1 block, problems with panning / zooming
printscreen unrecognized "something"?
hardware performance log.
Ok - message from Autodesk...
"They found that a file is causing the issue when two or more drawings with and without proxy elements are open at the same time.
As workaround, renaming the following file eliminates the problem without affecting the drawings.
C:\Program Files\Autodesk\AutoCAD LT 2014\AecCore.crx"
I've tried it for about an hour and seems ok - will test properly today
Loads of thanx for this topic and the answer! Had the same problem, now going to try the solution and hope it is solved for now.
Hello
And with the same DWGs opened by a standard ACAD 2012/2013/2014 : no problem ?
So it is really related ONLY (AecCore.crx) to ACAD LT ??
Bye, Pat
Patrice BRAUD
I have had the following reply from Autodesk regarding this problem -
I have changed the file name but then cad will not launch (Fatal error message) - What am I doing wrong?
Daryl
I have changed the file name back and software is now working albeit with flickering issue - Just wondering how others have changed the file name and got it to work??
Thank you,
Daryl
I've changed my too "_AecCore.crx" its flying along - but it is a temp fix/workaround though I've seen no side effects
Changing to "C:\Program Files\Autodesk\AutoCAD LT 2014\AecCore.crx.old" seems to work for me and my situation.
Excellent.
You can work "properly" with two drawings open in LT2012, try the same two drawings in LT2014 on the same hardware and it is virtually impossible to pan around.
File size doesn't matter, graphics doesn't matter, OS doesn't matter, RAM doesn't matter. Point is it works fine in earlier versions, it doesn't work in LT2014,
Don't try passing the book onto the hardware, certified drivers, cards etc etc etc
Autodesks issue.... get it sorted, period
Autodesk have provided a fix until a formal update is released - they havent blamed hardware
3.92 Meg file and 4.29 Meg file open: No problem
Added a 4.44 Meg to the mix: Just fine.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I've carried out the workaround as suggested, i.e. swapping the AecCore.crx from 2013, which has improved the running of the software.
The downside is that the command -Exporttoautocad is now missing.
Clearly AecCore.crx is the enabler for this command.
I've logged the problem through the Subscription Centre but has anyone come across yet another workaround for this?
Many thanks,
Steve.
Autodesk emailed me this:-
This is an update just coming from our development team.
A fix for this issue is planned for the next (SP1) service pack.
Renaming AecCore.crx is not an accepted workaround, it may lead to other issues.
Meanwhile, they recommend to fix this issue temporarily by update the registry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD LT\R20\ACADLT-D001\Variables\AECPSDAUTOATTACH]
@="0"
"StorageType"=dword:00000003
"SecondaryType"=dword:00000001
"LowerBound"=dword:00000000
"UpperBound"=dword:00000001
"PrimaryType"=dword:0000138b
// =================== reg file end =====================
Save the above text into a .reg file (eg fixLT.reg), and then run fixLT.reg to update the LT registry path.
