I installed AutoCAD 2012 for a coworker and entered the serial number for the product. Every time I go to launch it, it shuts down right away. I have tried reinstalling and all but no luck. I have even tried to run as administrator. Anyone have any ideas as to what is going on ?
Thanks in advance
No warnings or error messages, just closing down?
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Windows version?
There is no error message?
Try testing in diagnostic more to try and pinpoint any conflict:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6453117&linkID=9240617
If there are no crashes while in this mode, your issue is a system/hardware/software conflicts related problem.
