AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD LT 2011 - crashing when starting it
8 REPLIES 8
Message 1 of 9
tpnet
809 Views, 8 Replies
since today when I start AutoCAD LT 2011 it will pop up briefly and will close then - without any error or message. Even in the event viewer there is no entry. When I look into the task-manager the acadlt.exe will appear briefly and then will disappear again.
What I have already tried:
* installed the latest updates for AutoCAD LT 11
* installed the latest Windows Updates
* tried to start the programm as administrator
* tried to start it with different user accounts
* turned off Antivirus (Kaspersky)
All this didn't work.
OS: Windows 7 64bit
Standalone Edition
How can I solve this problem?
Greetings
8 REPLIES 8
Message 2 of 9
Charles_Shade
in reply to: tpnet
First try a System Restore to a couple of days ago and see if that clears this up for you.
If so - DO NOT install the Windows updates. I've found that .NET updates; especially, seem to muck with working editions of LT.
Message 3 of 9
tpnet
in reply to: tpnet
Hello Charles,
thank you for your help. I just tried your suggestion, but unfortunately it didn't work.
Any other suggestions how I can start my AutoCAD LT?
Greetings
Message 4 of 9
Charles_Shade
in reply to: tpnet
Follow this advice from Autodesk
Remove Autodesk Products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Grab a prgram named REVO UNINSTALLER (free) and remove the latest .NET and any updates to it.
Reinstall AutoCAD on a clean system. This will reinstall the .NET needed too I believe.
Message 5 of 9
tpnet
in reply to: Charles_Shade
Hello Charles,
thanks again for your help.
It wasn't .NET. After searching a little bit more in the www, I discovered that the service "FLEXNet Licensing Service 64" was deactivated - therefore AutoCAD LT 2011 wouldn't start. Re-enabling the service solved my problem!
I don't know what might have disabled this service.
Greetings
Message 6 of 9
Charles_Shade
in reply to: tpnet
Can you post the link to that solution in case someone else comes across the same problem and mark that post as Solved?
Message 7 of 9
tpnet
in reply to: tpnet
I have no link for asolution, as I figured it out myself.
What worked for me, was to enable the service "FLEXNet Licensing Service 64" again. After this, my problem was solved and AutoCAD LT 2011 started without any problems.
Greetings
Message 8 of 9
Charles_Shade
in reply to: tpnet
I was looking for whatever you had discoved on the www that led you to the FLEXNet Service.
Figured you had read something in a white paper or article or other Forum to lead you to that path.
Message 9 of 9
tpnet
”Boost
