AutoCAD Electrical Forum
IEC Standards Help
5 REPLIES 5
KLIPIT
2719 Views, 5 Replies
IEC Standards Help
Can anyone help me. I have been asked to produce a set of schematics to IEC standards. Can anyone provide me with a typical example. Many thanks.
5 REPLIES 5
testsubject
in reply to: KLIPIT
Oh, if it were that simple.
For starters, you will need to install the IEC Menus into ACE (I am assuming that you did not do it during the installation).
You do that by going to Windows Programs and selecting Add/Change for the AutoCad Electrical Software.
After adding the IEC Menus, you should have a sample of IEC drawings in your Projects folder.
Now the real fun begins.
I have been spending the past 8 months, on and off, redesigning our schematics into IEC format.
I recommend getting the following books to get you started.
IEC 81346-1
IEC 81346-2
IEC 61666
IEC 60204
IEC 61082
IEC 60445
Be prepared to spend about a $1000.
Then spend a lot of time reading and rereading these books.
Now you are close to starting to convert the schematics from JIC to IEC format.
You will have to create all your own symbols for your unique parts.
IEC is a completely different way of looking at machine documentation. I do like it now but it was painful getting to where I am.
Good Luck.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
metal_pro2
in reply to: KLIPIT
You can actually find a lot of the information with Google as far as the different IEC code specs. For instance IEC 61346
is one bit of information you will need. The place I worked for was to cheap to shell out a thousand bucks so I had to learn by example. Read this document from  Moeller I previously posted its very helpful.
http://forums.autodesk.com/t5/AutoCAD-Electrical/IEC-tag-for-Motor-Drives-VFD/m-p/3808329#M30284
One very important thing to learn with IEC drawings is they use Location (+) and function (=) codes. Usually in the right hand side of the titleblock you will see some thing like this.
                 =RRM
                 +QP1
In this sample
RRM - is the function code for Reversing Rolling Mill
QP1  - is the location code for the Panel (multi door panel so there might also be +QP1.1, +QP1.2)
I have attached a couple documents I found on the web that might help explain some of the IEC symbols
metal_pro2
in reply to: metal_pro2
Here is some Sample IEC drawings.
OP21
in reply to: KLIPIT
There is a very good Autodesk training guide for IEC fundamentals using AutoCAD Electrical.  Check it out via Ascent... As for custom symbols, web searches or links from the previous posts are really very helpful..
Good luck!
Omar
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
in reply to: OP21
Hi
An interesting thread.  I do not need to know but thanks to those who responded.  If I ever need to I know where to go.
Cheers  John Q
”Boost
